Satyrist
- Mar 12, 2001
Specs:
Foxconn 6150K8MA-8EKRS MATX board
Opteron 144 + Better AMD Heatpipe cooler + 92mm fan (with 80mm mounts)
2gb GSkill PC4400 DDR
H.I.S. Radeon X1900XT 512MB DDR3 (Came with Arctic Cooler-style Fan on card stock)
Seagate 160gb SATA
Seagate 320gb SATA
NEC 3540 DVD
Turtle Beach Santa Cruz audio
USB2 PCI card (onboard ports not functional anymore)
Inside of a Microfly case with an Enermax Liberty 500W.
I've had some issues where the system simply shuts down immediately a few times now, and will not turn back on when pushing the power switch; Unplugging it for a little bit, (5-10 minutes) then plugging in again, will allow for power on.
The shutdowns only seems to have exhibited itself on the character select screen of Dark Age of Camelot;
I've played UT2004, BF2142 for hours and hours at a time without issues or shutdowns.
I had been using an older version of Catalyst before, I went and upgraded to the latest version yesterday. (7.6)
Now, I haven't yet run Memtest as of yet, and everything's been running stock for a while now. Signs point to a few different things I know,
-PSU
-Memory
-GPU
-Motherboard (haven't looked at it yet for suspect capacitors and so on)
I'm not so sure that temperature is a factor here, (as mentioned before) and the only place thus far where I've been able to reproduce this problem at all doesn't seem horribly gpu/memory intensive.
My question is, which component would best exhibit this type of behavior?
Seagate 160gb SATA
Seagate 320gb SATA
NEC 3540 DVD
-PSU
-Memory
-GPU
