Wheresatom
- Mar 20, 2007
In the last couple weeks I have had my computer BSOD 4-5 times I believe. I had not changed any settings on the computer. My CPU HSF is clean, and I have been paying better attention to the temperatures and am not seeing anything out of the question. Max temperatures have been around 40-45c. After the first one, in an attempt to treat the symptoms rather than cure the illness I reduced my OC from 3.2 to 3.0. It has BSODed a couple times at that, and even last night gave errors in the SMP at about the 3rd step of whatever work unit it was.
Anyway, so basically, I think I have fried something. A few weeks ago when I went to put my USB drive into the computer, a spark went from the usb to the computer (or vice versa) and the computer turned off. No shut down sequence just off. This happened twice I think over the course of a couple days. Since then I have been a bit better at topping off the humidifier and there is less static, but the damage is done. I assume these shocks have hurt some component in my computer.
The question to me is, which component? I am not very experienced with this type of thing so I don't know what breaks when this happens. Is this going to be a big trial and error situation where I just have to swap out parts till it works again or is it most likely one component?
I hope this isn't expensive.
