Sudden 8800GTX CRAP OUT
KillaChaos
Yesterday -
Everything is going fine turn off the computer and go to bed.
Today -
Returning from a bbq I turn my computer on and nothing! Everything seems to work, so after much fiddling around, I switch to intergrated gfx and it works. Wtf happened to my gpu? I always put the case cover back on so outside forces shouldn't be at work. Could my gpu just died?
EDIT: 6200 doesn't work either? now im just confused.
Try reseating the card and reconnect the power cables.
See if the fan spins up on it.
If two video cards are not showing a picture, it's probably your motherboard that died. Strip it down to the bare essentials: Motherboard, processor, one stick of ram, video card, one hard drive. Reset the cmos and see if it will boot.
Possible the PCI-E slot died. I'd look closely for signs of overheating/damage on the slot's connectors.
Thanks, I started to panic when a $400 at purchase part just stopped working. Reseated and cleared cmos and it worked.
But I wondered why it failed all the sudden.
Good to hear. I'd still suggest cleaning the card's connects with some rubbing alcohol.
Might be a film building up reducing it's contact.
