Such thing as Super-Sized Lanboy or equivalent???
ttfing
Any suggestions on a case that has the same inner construction. I like how the Super Lanboy is designed; not necessarily color and LEDS, but with the way everything is put together. I like how it has 1x120mm fan in front of the harddrives mounted sideways, and the 120mm fan in the rear. Does anyone know of a similar design case, but with more slots for hard drives?? I need this for a file server. Can't find anything similar, only ones with 80mm fans.
It just looks like a bigger version of the Lanboy. I need something w/ more hdd slots available.
specify how many hdd slots you need....
edit: thats what you asked for as well....
If you want 4 hdd, you can check the Chenbro SR209 or SR107. With some more bucks, you can get a hotswappable SATA drive cage for 4 HDD and you can fit 1-2 more in the 5 1/4 bays.
