Now that I am able to get on the network, man...is the network slow! Everything is firewalled, forget about playing any games (can't play Doom 3 online for instance). Can barely use any filesharing programs. But I was wondering...and someone critique my logic (maybe it's a little slanted)
Typically a college's firewall is up to protect them legally as well as from viruses, worms etc. It also helps the bandwidth (no one is downloading/playing games, so you can spend less on more people) Essentially no one has a choice in using it, the ethernet cost is calculated in your rent for living on campus.
Do you think it would be possible to have someone like, COMCAST or Roadrunner hook me up to cable on campus? They only need a cable line to do it right? And I would be on an ENTIRELY different network from UNF altogether so they would be protect legally and from virus I might acquire from playing Doom 3.
I suppose it doesn't hurt to ask the system admin or whoever is in control. 40 bucks a month is well worth it, especially if you split it with a roommate. I am just trying to get all the arguments worked out ahead of time.
If they are worried about me being connected on cable then distributing viruses to the school network they could just blacklist me so I couldn't connect, because then it wouldn't matter anyhow since I'd be using the cable connection. Legally they are protected since Comcast would be the ones to worry about. And besides, didn't a Supreme Court case rule that the ISP's CANNOT be held liable as long as they cooperate and give out the names?
All I want to do is game really but I know they don't care about that. So basically I have to somehow convince them that, even if I were the world's most brilliant hacker, that if they let me have a Comcast guy install cable, they would be totally clear from any legal problems.
What do you think?
What do you think?
