Mister X said:What good is a muting circuit gonna do here?
You need some type of mains filtration to deal with these kinds of issues.
You are right when you suggest that most consumer audio gear does have a built in mechanism to deal with micro power surges but when did that ever apply to PC speakers?![]()
mikeblas said:All consumer audio gear, even PC speakers, has a built-in mechanism to deal with micro power surges: the power supply..
mikeblas said:A muting circuit turns off the output of the amplifier at start up until the power supply becomes stable. Some circuits will do the same thing at (or after) power off.
Mister X said:What part of the PSU do you think provides this so called built-in mechanism that deals with these micro power surges?
[/QUOTE]Mister X said:So, what happens to this muting circuit when the power supplies built in mechanism for dealing with micro power surges shunts this micro power surge to ground?
mikeblas said:What are you trying to do? Fix the problem, or understand why it is happening?
