I've been using the command line for comparing files but the fc.exe doesn't include subdirectories.
I just need a basic utility for comparing to directories. I copy a lot of files, and i'd like to be able to check if everything got copied properly.
Google turned up quite a few results but i'd like to get a recommendation from you guys. Thanks
