Sub 1k Comp help
Mightymouse
ok i've been workin hard over the summer tryin to get some money for upgrade/building a new comp. i dunno which to do since the upgrade would b to buy everything but the proc. + motherboard which still puts it at like 700 dollars whereas building one(i would like) would be almost 1k
SAPPHIRE ATI RADEON 9800 PRO Video Card
194.00
AMD Athlon 64 2800+, 512KB L2 Cache, 64-bit Processor - OEM
173.00
ASUS "K8V" K8T800 Chipset Motherboard for AMD Socket 754 CPU -RETAIL
105.00
Corsair XMS Extreme Memory Speed Series, (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-3200 - Retail
236.00
Western Digital 200GB 7200RPM IDE Hard Drive, Model WD2000BB, OEM Drive Only
113.00
ZALMAN CNPS7000A-Cu Pure Copper CPU Cooler for AMD XP Socket 462/ 754 and Intel Socket 478
40.99
NU Technology Black 8X DVD+RW/-RW Drive, Model DDW-082 BLK
65.99
Rosewill ATX Case with 400W Power Supply and Side Window (Black), Model "TU-155" -RETAIL\
65.00
subtotal $979
suggestions/modifications? help is appreciated.
You could save a chunk of change if you didn't buy such high end RAM. I use Crucial PC3200 in my system, it's great stuff. Unless you're gonna do a lot of OCing, I don't think you'll notice much performance difference between the two kinds of RAM and their latencies.
You will do fine with a regular Zalman CNPS 7000-AlCu - they're much lighter than the all copper version, and it cools almost the same, to be honest.
As I've never heard of Rosewill and have no idea what the PSU it comes with is, get a different case with a name brand PSU, like an Antec. I can't really stop you from getting what you want here though.
DVD-RW drive: I'd rather get an NEC ND2510A - dual layer and only like $80 anyways; plus, NEC drives are excellent (I use an ND2500A myself).
oh ok thanks for the advice
this is the case i was really looking into also
ANTEC P160
http://www.newegg.com/app/viewproductdesc.asp?description=11-129-141&DEPA=1
this RAM ok?
Corsair Value Select Dual Channel Kit 184 Pin 1G(512MBx2) DDR PC-3200 - OEM
http://www.newegg.com/app/ViewProductDesc.asp?description=20-145-480&depa=1
DVD drive:
NEC 8X Dual Layer DVD+/-RW Drive, Model ND-2510A SVR, OEM
http://www.newegg.com/app/ViewProductDesc.asp?description=27-152-025&depa=1
COOLER:
ZALMAN CNPS7000A-AlCu Aluminum + Copper CPU Cooler for AMD XP Socket 462/ 754 and Intel Socket 478 -RETAIL
http://www.newegg.com/app/ViewProductDesc.asp?description=35-118-108&depa=1
good power supply? i dunno what the "name" brands are.
