SUB-120 or V-1220?
Eugenester
Title says all, Dayton is $159 at PE and the BIC is $160 at Amazon. Spec wise, the SUB-120 does 25-180Hz and the BIC does 23-180Hz (+/- 3db). Also, the BIC has a LFE input which saves me the trouble of buying a coupler. Use will be 50/50 movies and music, but SQ>SPL. AVR is a Denon AVR-591 which does EQ the sub. Thoughts?
Edit: The BIC is a downfiring sub, and I live in an apartment that resonates very easily =(. I guess the SUB-120 would be better for my situation but I would like some opinions nonetheless.
I wouldn't get a subwoofer in an apartment.
Consider bass shakers.
I mostly play movies during the day, or on weekends, when the neighbors don't mind or are at work. Bass shakers do seem nice, but I would like to hear LFE effects instead of just feeling the vibrations.
I also had to make the same choice. I eventually went with the Dayton because it had the inputs/outputs I needed to connect everything together. The v1220 didnt. Overall the v1220 should be better even though it's a down-firing sub. Just make sure you can connect everything.
Oh and I love using my sub in my apartment. I just turn it down at night.
Well for me a sub. in input is all I need. But why should the V-1220 be better?
Title says all, Dayton is $159 at PE and the BIC is $160 at Amazon. Spec wise, the SUB-120 does 25-180Hz and the BIC does 23-180Hz (+/- 3db probably). Also, the BIC has a LFE input which saves me the trouble of buying a coupler. Use will be 50/50 movies and music, but SQ>SPL. AVR is a Denon AVR-591 which does EQ the sub. Thoughts?
that 23-180hz can be 50hz@-30db
Wait until the BIC F12 is ~$160 shipped to your door. It seems to happen 4 times a year. At that price, it is a much better speaker.
Hmm..F12 is front-firing and is shielded. MSRP is the same as the V-1220 but the lowest price I can currently see is ~$185. It looks delicious too :cool:. Seems very good, but it's gonna be one hell of a find. Do you by any chance have a link to a seller for $160 bananas?
Edit - SQ-wise, I'm guessing the F12 is going to be better, yes?
Edit Mk. II - Apparently on the AVS forums the generally consensus is that the F12 is overrated and a nice "starter" sub (based on skimming threads, so could be wrong).
It is a top rated sub in your price range. $160 is a sale price, you'd have to keep your eyes open. But for $185, it is still a good deal.
As far as being overrated, keep in mind most people on AVS have 2-4 $1k + subs in their homes.
http://www.avsforum.com/avs-vb/showthread.php?t=1246684
True, those SVS/HSU subs are pretty expensive (at least in my case); but a lot of people there have budget subs as well. I guess I'll have to resort to scouring the 'net for a deal.
-I can't seem to find any reference to the sub going for $160.
Just got the BIC V80 for my small apartment. I think it's perfect for an apartment. It's also $100 shipped.
SUB-120 does 25-180Hz and the BIC does 23-180Hz<---- They can do that at-9db or -16db. Dont believe that BS
What is your budget? Get the Dayton SUB-100 10" or the Yamaha YST-FSW050BL2 . 12 is for meduim to large. You will be wasting your money. Get the 10
All sub companies rate their subs at +/- 3db, and the high end manufacturers do 1-2db. Dayton and BIC America are reputable companies, and their stuff has been reviewed all over the place. I'm specifically looking for a 12" sub under $200.
The Dayton SUB-120 is great. Used it in an apartment(had to keep it pretty low) until I replaced it with a Martin Logan Dynamo.
The BIC H-100 and F12 are decent too, but I would pass on the V-1220.
Uh the Jamo A70 10" 450 sub on vanns is $199 free shipping.
Usually $699. Jump on that.
