1. Yeah, it should remember what size it was when you last closed it. If it gets confused, open it, resize it, and close it before you do too much else. Works for me, anyway.Archer75 said:Tried that, would'nt let me resize.
Will it remember the size of a window when I resize it and then open it to that size every time it is launched? Or will I have to manually resize it every single time?
Also, where do I go about checking the processors in the system, the ram, the hard drive, superdrive, etc. I just want to make sure everything is in the system that is supposed to be. Just bought it off ebay.
I'm stuck at work so I can't play with it right now. Couple more questions. What are .dmg files and what do I do with them? How do I install programs? Same as windows? Double click?
Anything else a newbie should know?
nah, i think he is looking for the active programs, in which case it is:DatHak512 said:2. Click on the Apple menu -> About This Mac -> click the button More Info, and that should get you what you need.
Archer75 said:...Also, where do I go about checking the processors in the system, the ram, the hard drive, superdrive, etc. I just want to make sure everything is in the system that is supposed to be. Just bought it off ebay...
Black Morty Rackham said:Is your Mac slow? Buy more RAM. If you have less than 512MB, that's probably the cause. A dual G4 is generally quite quick.
As for window size... Get used to not running full screen! Trying to make Mac OS behave like Windows is just stupid. Not running full screen is a better UI design, so try to relearn instead!![]()
Archer75 said:I am running OSX 10.3.7, I have 1gb of ram.
I don't want to have to get used to not running full screen. Why should I have to? Should the OS not allow me to set things to my liking?
I get rather irritated not being able to see all files on the screen and constantly have to scroll up and down is not my idea of being productive.
I wonder what retard though of that? fucking doing it manually is stupid. Thats one of the main reasons I HATE macs. Its totally not user friendlyKaosDG said:"maximize" works different in OSX vs. Windows. Basically it's a "use as much window space as needed" not "fill the entire screen"
You'll have to manually adjust the window size beyond the green plus setting.
That's one of the hardest differences for me to get used to.
Bugalaman said:I wonder what retard though of that? fucking doing it manually is stupid. Thats one of the main reasons I HATE macs. Its totally not user friendly
Bugalaman said:I am entitled to my opinion... ass
if you hate macs so much, what are you doing in the mac part of the forum in the first place? just here to troll or what?Bugalaman said:I wonder what retard though of that? fucking doing it manually is stupid. Thats one of the main reasons I HATE macs. Its totally not user friendly
you know, this isnt a bad thing. you are just so brain washed by windows that you dont even want to entertain a new way. there are things about windows that i absolutely hate, or dont make any sense, but since i cant do anything about it, i have to deal with it. after using osx for a while, you will learn to like it and things will make more sense to you and you will start to like it better than windows. dont be a pussy, and think about it, windows is full of things you dont like, but you have just gotten used to them. you dont like osx, get rid of your mac an use your windows box. not trying to be a dick, just say stop whining that it wont work like windows, and start learning how an os SHOULD work.Archer75 said:I don't want to have to get used to not running full screen. Why should I have to? Should the OS not allow me to set things to my liking?
wankrtron said:just say stop whining that it wont work like windows, and start learning how an os SHOULD work.
