Stupid Question
vjcsmoke
Do you have to buy caps for your gpu waterblocks. I've got comp fittings and an SLI connector go in between my two waterblocks. But do I need to buy end caps or is that like provided with the block?
Quick Diagram:
Here's what the kit includes: [It's the one on the left]
So do I need to buy end caps for this? I'd be pissed if all my stuff arrived and i couldn't hook up the blocks because I overlooked something as simple as this.
I was able to call sidewinder and add a couple of Bitspower stop fittings to my order before my stuff shipped out! Phew. So everything should be ready to go when the rest of my WC components arrive - waterblocks, fittings, tube cutter, etc.
