Everywhere I look, this board is a AM3/AM2+/AM2. However, when I received it, the states it's AM2+. Will this work with a Athlon x2 3600?
Yes, an AM2 CPU will work in an AM2 compatible board.
just correcting your post since its 99% right and no use for me to correct it by writing it out myself.An AM2 processor will work in an AM2 or AM2+ board.
An AM2+ processor will work in an AM2+ and most AM2 boards with BIOS update - although HTT will be limited.
An AM3 processor will work in an AM3 and most AM2+ boards along with some AM2 boards with BIOS update - although HTT will be limited.
Note that AM2/AM2+ are DDR2, and AM3 is DDR3. An AM3 processor has both DDR2/DDR3 memory controllers on the die, which is why it will work in either board. An AM2 and AM2+ processor only have DDR2 controller and thus can't be used in an AM3 board.
Also: I have an AM3 cpu working in an AM3 board the bios just doesn't recognize it properly....
Right. I just got concerned because the box states it's AM2+ and doesn't say anything about AM2.
Which board you talking about ?
If the CPU is AM2+ it will work on AM2+/AM3/AM3+ motherboards.
If the CPU is AM3, then it won't work on AM2+ and lower boards. (Well, it *might*, it just depends on the board)
*edit, I don't think they made a AM3 version of that CPU...
