Stupid question about DVI to Component adapter
adg1034
This links to a Newegg page for a DVI to Component video adapter. Look at it. I'll wait. As far as I know, there's no reason this shouldn't work, but I thought I'd ask anyway: I'm planning to buy one of these so I can play my Xbox 360 on my Dell monitor (that doesn't feature any inputs other than VGA and DVI). Here's the stupid question- conversion between DVI and component is 2-way, right? I'm only asking because the product text mentions it as a way to turn the DVI signal from your video card into a component signal for your HDTV, and nothing about the other way around. Have any of you done anything like this before, and would this work?
Yes, thank you. If you read the post, you'd see that that wasn't my question.
Being a butt-head isn't going to get your question answered any faster ;) :p <3!
As for the main question, no, it will not work. The card does not have a DVI input, so the component adaptor cannot work as a component input.
Ok to more directly answer your question, no you cannot use this as a component to DVI converter to play your XBOX 360 on your Dell monitor, hence the made for older Radeon cards answer above.
Well, if that wouldn't work, does anyone have any ideas on what would?
EDIT: Never mind. I just found out that all I'd need would be to buy a VGA cable for my 360. D'oh!
Until MS come out with HDMI stuff for all digital that is going to b your best bet.
