Oct 31, 2006 #1 J jcll2002 2[H]4U Joined Jan 28, 2006 Messages 3,655 All of my PCI slots are currently being used and I really want to use my PCI tv tuner. The only slots I have left are an x1 slot and a PCIe slot. Will I be able to use this PCI card in a PCIe slot? Will i completely blow something?
Nov 1, 2006 #2 S sirholio Supreme [H]ardness Joined Mar 9, 2000 Messages 4,388 I'm pretty sure you're not going to be able to fit a pci card into a pci express slot. http://en.wikipedia.org/wiki/Image:PCIExpress.jpg
Nov 1, 2006 #3 A Arcygenical Fully [H] Joined Jun 10, 2005 Messages 25,066 I'm sure you could cram it in... But I'm also sure it wouldn't work
Nov 1, 2006 #4 Astral Abyss 2[H]4U 2FA Joined Jun 15, 2004 Messages 3,266 PCI and PCIe are not compatible in any way.
Nov 1, 2006 #5 J jcll2002 2[H]4U Joined Jan 28, 2006 Messages 3,655 ok ok thats why i wanted to make sure. Anybody want to buy my PCI tuner
Nov 1, 2006 #6 A Askanison Limp Gawd Joined Mar 21, 2006 Messages 244 there are pci-e to pci converters...but your pci card would have to be half height type.. to fit to any standard casing
