Stupid Error Message - CPU Related?
MrHood22
I just installed my Q6600 and i booted up and i got this error:
"windows media player network sharing service stopped working and was closed"
My Zune software also doesn't work.
I don't think it's CPU related though. Odd thing is I had my computer unplugged for 2 days, came back, popped in new CPU, turned it on, now i get this?
Is my computer mad for not using it? :p
Suggestions?
I highly doubt it's the cpu. If you have any extra thermal paste and if the error is reoccruing while the new cpu is in then i would reswitch with the old cpu. Just to rule out this is the case! It could have been spyware related?!? Or corruption that only showed itself once you restarted. It could have been working normal then you shut it down unplug then come back and bam you get harrased by your pissed off lonely computer.:p
Is there anyway to redownload the file and overwrite whatever is causing this problem?
I tried that when SP1 was uninstalled and then I tried it once more when it said it was successfully installed, both times it didn't work.
Any other ideas?
