- Nov 13, 2002
It's definitely worth it if you have the funds and even better if you'll also benefit from the extra processing capabilities in other apps.Good info, and thank you! I have not picked up on the Xeon requirement, but I did just read through the thread about the new low voltage chips...
What CF components are you looking at?I am so curious I might actually give up beer for me, and carbon fiber for my bike just to try some dual quad / hex goodness... Foe serious work, only.![]()
I just noticed that my MB will support a Phenom II X6, but I don't turn up anything around here, and FAH addict seems to think they are worth about 12K, which would be a much cheaper upgrade.
You mean the F@H graph with the 980x at top? Well, that's an excellent processor and absolutely recommended if you are unsure about the SR-2. Those processors OCed are monsters.And I just found this over at tech report- might even deserve its own thread... thoughts anyone?
http://techreport.com/articles.x/18799/13
Those benchmarks are useless. They only test with the standard client so the PPD values they get don't reflect what you will actually see from using the SMP client (or the fact that i7 CPUs can fold -bigadv units and get an even bigger boost in PPD).And I just found this over at tech report- might even deserve its own thread... thoughts anyone?
Yea- the 1055T looks like a winner... Did you say that's in your farm? I have to admit, I can't imagine not using the best machine I have for my own amusement- you are a better man than I...![]()
My SR-2 is going to be my primary desktop as soon as I get a case for it. It should be able to handle Quicken.![]()
