Hey guys,
I'm having some major issues getting my Opteron 170 to stabilize at any decent speed since Super PI and Prime95 both fail constantly within minutes. I just received my new Opty 170 and swapped it with my previous CPU which was a Opty 148. The 148 could easily run at 2.8ghz (255x11) at 1.45v. Therefore, I know my RAM isn't the culprit here since it could run even at 270 at 2.8v with no problems at 1:1 with my 148. The 170 I have has the CCBBE 0610DPMW stepping which is supposed to hit 2.8ghz and all I am trying to accomplish is 2.5ghz (250x10) to start. I'm not new to overclocking as I've had pretty good success with other CPUs but this is my first dual core CPU and I'm not sure if I'm going about it properly. I'll list off some of my BIOS settings I am currently set at:
FSB: 250mhz
LTD/FSB Ratio: 4x (1000mhz)
LTD Bus Transfer: 16 16
FSB Mult: 10x
PCIE Frequency: 100mhz
CnQ Support: Disabled
CPU Vcore: 1.45v
LTD: 1.2v
Chipset: 1.52v
DRAM: 2.8v
DRAM Frequency Set (Mhz): 200MHz (1:1)
Command Per Clock (CPC): Enable
CAS Latency Control (Tcl): 3.0
RAS# to CAS# Delay (Trcd): 3
Min RAS# Active Time (Tras): 8
Row Precharge Time (Trp): 3
Row Cycle Time (Trc): 10
Row Refresh Cyc Time (Trfc): 16
Row to Row Delay (Trrd): 2
Write Recovery Time (Twr): 2
Write to Read Delay (Twtr): 2
Read to Write Delay (Trwt): 3
Refresh Period (Tref): Auto
DRAM Drive Strength: Auto
Max Async Latency: Auto
Read Preamble Time: Auto
Idle Cycle Limit: 64
Dynamic Counter: Enable
R/W Queue Bypass: 16x
Bypass Max: 07x
32 Byte Granularity: Disable (4 bursts)
As you can see, my settings are not very tight as I've had my DRAM settings even tighter with my 148. As for the BIOS itself, I'm using the latest version from DFI and I have a clean Windows install (doesn't really matter) with all the latest drivers for my components. My temps are all good across the board, all well under 40 degrees (Celcius). I'm not sure what else to post but any advice will be greatly appreciated.
Thanks!
P.S. Refer to my sig for hardware details.
FSB: 250mhz
FSB Mult: 10x
CPU Vcore: 1.45v
LTD: 1.2v
Chipset: 1.52v
DRAM: 2.8v
Bypass Max: 07x
Thanks!
