Check out the CableCard links.
From what I've read, you have to have a certain computer for them to even work
From what I've read, you have to have a certain computer for them to even work![]()
Would a regular tv tuner even be worth it then?
so what do these even do? http://www.newegg.com/Product/Product.aspx?Item=N82E16815293003
what media player are you guys using? I want to use win 7 but would like a nice interface to my TV when browsing movies
Easiest way I've found is to set up the remote as an MCE Keyboard in the Logitech software. That way you can assign the buttons to a keypress on a keyboard.
There's a list of XBMC keyboard shortcuts here.
You can also get more involved, editing the keymaps.xml and such but try that out and if you need more there are a lot of resources out there.
This thread is fucking ancient and should be unstickied.
Whos the mod here anyways? I suppose they should be contacted with some sort of idea on what thread should be up top.
