D
Deleted member 71337
Guest
Here is the system I am working with:
P4 2.6g 800mhz FSB
Asus P4P800 SE with 1010 bios- most up to date- I reflashed from 1001 with dos boot.
512mb DDR 266Mhz
120gb 7200 RPM WD HD
Nvidia 5200 Vid Card
Plex CD R/RW
ThermalTake 420w PS
ThermalTake Xaser SuperTower
Was given the case by friend because he said he was having random reboots. He started the re-load the OS but he said he cannot get past a certain point. (get to that in a minute)
After hearing his description(too detailed for this), I replaced his PS with the TT PS. He was trying to run all the fans, all the above hardware and another optical drive with a 220w PS.
So here is were I am. I tried to continue the reload with a full official version of XP pro(NEWEGG). I get all the way to the first reboot where it says 39 minutes to install left... the moving dots stop after a bit and it freezes. On reboot it goes thru system hardware recognition and the randomly... goes black and reboots to start over, makes it to splash screen then freezes or reboots, makes it to "39 min left" screen and freezes.
Things I have tried. Reformating and restarting OS install (again and again), re seated everything, updated bios, swapped out with known good vid card, ram, hard drive, optical drives (removed a bad one and replaced damaged 40 pin cable), and removed CPU HS and Fan and reinstalled with Artic Silver ceramique. Tried reducing power consumption by removing all but 2 fans(CPU and I case fan). Using on board sound and no other cards installed for now.
All fans are installed on one rail and hard, optical drive, floppy drive are installed on second rail.
All bios setting cleared and defaults loaded, with CPU and ram speed checked. CPU temps are normal at 25-31 deg Celcius as read by MoBo temp gauge. All power readings are good (also according to BIOS). Tried a few different bios settings(nothing OC) but none have any affect one way or the other.
In all I am stumped. I went back 15 pages in this forum and found nothing close enough. I am concluding that either the CPU or MoBo or both are damaged from last PS. Anything I am missing? Or any suggestions?
Dan
P4 2.6g 800mhz FSB
512mb DDR 266Mhz
Plex CD R/RW
ThermalTake 420w PS
Dan
