stuck:( questoin about clock and core speed
the x800xl is better hands down.. you may not get the 475mz clock but you get 16 pipes and ther is a good chance you'll be able to oc to around 430 or so.. either way the 16 pipe card is way faster than the 12...
ops, I ment to check out pipelines but I guess I forgot. Thanks for the response.
question answerd
I was wondering if someone could elaborate on what Pixel Pipeline effects when dealing with gaming? In other words take a look at this link http://www.newegg.com/Product/Produ...2E16814150154,N82E16814130037,N82E16814130034 , the two main differences are core clock and pixel pipelines. If someone (me) were to go with the cheaper card where in performance would I take a hit?
Both will have an effect on performance. The 6800XT is really a lower end mid-range card. Something like a 7600GT would be better, but for price/performance, the 7900GT you have in the list would be good, or just a plain 7900GT (not the KO).
The X1800XT is also a good buy at $199.
Thanks for the quick reply, however I thought that the KO was the revised version better than the previous buggy one - or did I get my info mixed up? I'm actually avoiding ATI because I've had nothing but bad luck with every card I bought :( Its a shame because I know they are great cards!
The KO is actually a factory overclocked version of the 7900GT. If you look in the Core Clock field it says "560MHz (standard 450MHz)"
The KO does not indicate a revised version for the power problems that were causing the 7900 series cards to fail.
What am I missing, the links take me to a page full of different videocard models not specific products. Which 2 cards are we actually comparing? :confused:
Try the link in post #6.
Gotcha, thanks. I did a bit more research and its "Reload" or "Reloaded" I should be looking for, for the revised card.
