Stuck pixels!!
Okibi
So I'm on my second Dell 2007WFP and yet again I have a stuck pixel right in the middle of my display. I set up an exchange for my first one because of the same thing. ARGH! It seems like everyone else has really good luck with not getting any stuck/dead pixels on their Dells? I'd really like to just get a perfect one. What do you guys do? Should I just keep asking for an exchange?
Thanks guys. I had a chat with tech support and I have replacement #2 on the way...
Also, I'm trying the massage thing. No luck with it. I'm running UDpixel on it in the meanwhile, though.
I'm also returngin mine for an exchange. The 1st one had banding and back ground light bleeding problem and the 2nd one had a blue stuck pixle in the middle. Once you see the stuck pixel, you cannot keep an eye off of it. I hope new replacement will be without any issue. BTW, the 1st one is rev. A02 and the 2nd was was rev. A03. Both made in Mexico.
Yup, my first one had a stuck blue pixel in the middle too. Same with the first one being rev A02 and my replacement being an A03. I can't tell a difference between the two panels otherwise. A03 seems to be S-IPS..
