Delicieuxz
- May 11, 2016
Asus X670E-A
Ryzen 7700X
16 GB RAM
RTX 3080
Today, when waking my PC from sleep, as normal, the screen stayed black and the case fans were a little worked up, like when booting the system. I thought it might be restarting, but it just stayed like that for a long time. So I powered off at the PSU and powered up again. It didn't seem to move past the memory training stage, so I opened the case and saw it was stuck at the white VGA light.
I removed the battery, power cable, and held the power button down for a while, then restarting. The issue persisted.
I had upgraded the BIOS to the latest version a day or two before, so I thought that could be causing the problem. I downgraded the BIOS using Flashback and tried again, but the issue persisted.
I next tried removing the GPU and connecting my monitor to the onboard graphics port, using an HDMI cable instead of the DP cable I normally use, then powering up. The issue persisted.
I then tried removing everything but the CPU and soundcard, and powering up. I got the orange DRAM light.
Then I tried with only one RAM stick installed, and I got the white VGA light again.
Any tips on what could be the issue, and what should I try next?
Ryzen 7700X
16 GB RAM
RTX 3080
