Stuck, Neverending computer problem.
Jondbold
My server recently needed it's motherboard replaced, It was an intel 875p fbm 1.5 (full name escapes me right now) board. Newegg replaced it with an ABIT "IC7-G MAXII ADVANCE" after an rma.
A few months later the hard drive started to click. An old maxtor from 2000 that finnaly died, So I replaced it. I installed windows xp and the boot times took forever and the one or two times it made it into xp it just lagged and would never open anything the mouse was movable, but nothing seemed to open. So I re-installed it and had the same problem. Once more I tried it with another cd and the same thing occured. Next I tried replacing the dvd-drive and trying a third copy of xp. Still had problems.
Then I began giving it the full run through. I mem tested it, checked out. Tried a working pci-ide controller to test if the onboard ide controller was bad. I replaced the hard drive with a sata one and it started experiencing copy problems arbiatf or some font file it choked at the first time, the second time it made it through the install and had problem locating some random system file. I replaced the power supply next with a antec neopower 480. Stripped it down to just a 9600xt. I've done everything I can think of.
What I suspected was overheating but it's running at 42-45c in the abit bios (If I remember abit boards report heat higher then the actual setting.. ) Perhaps the cmos battery ?
I've ran out of ideas and have already asked 2 or 3 equally qualified friends who are boggled by it and suggested everything I already tried. So what else could it be ?
Thanks.
Your old Power Supply could have been killing and dammaging your components... Some of which the dammage still lingers.
What was the Old PSU?
hey that mobo is bad dude .... id suggest cross exam but if you dont have some spare parts around, its really hard to find a culprit...
I have spare parts around, but I know the ide/9600 xt work in it as well as the memory so that rulled out the components being bad imo. I've tested them in different machines and mem tested all were a-ok. I'm with you though at this point I think, the mobo is the newest part... although I'd like to dig a little deeper because this will be the third mother board i've replaced in a year for this thing.
Well I thought rmaing was going to be easy but newegg refuses to take an item back they already rma'd, so any more ideas to try before I go through the hassle of abit.
