Stuck CPU socket lever?
cocoa999
I have a NF7 that seems to have a stuck lever on the CPU slot - it won't lift up, and I'm at the point where applying more force would probably snap the flimsy plastic bar rather than do any good. Anyone had this? Any suggestions?
How's it look? Anything in the way?
I dunno if the socket is the same as others I've used, but are you pulling it away from the socket slightly, then lifting?
Nothing really looks unusual... I've built quite a few systems and swapped CPUs on this particular board a few times and never had an issue like this. Yeah I'm doing the pull away - lift thing.
try a flat screwdriver insert between socket and lock and [ush the lock out and up
