infinity4life
- Dec 23, 2005
I have an amd 4800+, asus sli-premium and SLI'd 7900GTXs, and 2gb corsair ram
Cooling is a Zalman fan (i forget the model) .....the problem is I can't seem to overclock past 5%.....5% everything runs smoothly and perfectly. try to get to 6% and I can boot into windows, but 3dmark crashes after 2seconds. It doesn't matter whether I manually play with the settings or use asus's default options (e.g., for 5%, 8%, etc...), it just doesn't want to push past a 5% o/c. I've read that the SATA ports may be unlocked in this board so they o/c along w/ the rest of the stuff and can cause it to crash, but I need to use all 4SATA ports so I can't exactly switch them around, heh. (I'm hoping that's not what's causing it to crash)
Any ideas why?
Any ideas why?
