I'm doing some remodeling and have a closet I'm planning to build that is pretty much in the center of my house and will be used as a structured wiring closet and will also house a hp 24u server rack. In the future this will serve as central media store and perhaps even hold amps. It is in the lower level on the slab and is not on an exterior wall of the house. The closet will be a little shy of 4' deep and 3' wide. PVC pipes come in at the top through a wall from the floor upstairs which continues to the attic. All the wires from all rooms drop through these pipes to this closet. Wiring panels will be put on the wall and obviously the server rack is on the bottom. At first I was just planning to use a vented closet door. Since everything is down now and about to be built I figured I should rethink whether it is worth putting in some cooling now. I am not spending a fortune on this and will be heat conscious when purchasing equipment. Wondering what my options for cooling are though.
The rack has a built in slider type thing on the top made for taking exhaust ducting. I'm thinking maybe I just hook up a duct to it perhaps with some kind of inline fan or something maybe triggered by a thermostat in the closet and that would suck up hot air and vent it out of the closet. Then the air would be sucked into the cabinet in the front through the vented closet door. At least that provides some circulation and exhausts hot air (into the rest of the house). Anyone know of something made for this purpose? Any other ideas?
