- Oct 13, 2004
ok this is a friend of mine that needs a few answers that cant find a email to use to register..
tho i have no idea what hes saying... try to comprehend and make your best judgment.. thanks !
I just had a quick question for everyone here. I just purchased 2x 250GB western digital SATA II drives (WD2500KS operating at 150MB/s SATA I speed) and have them set up in RAID 0. What would be the most appropriate stripe size for the RAID array? I am currently copying my system drive which has 40GB worth of files on it and it has been copying for about an hour now and is only half done and I am a bit concerned that this is a little slow for SATA RAID. The PC I am using these on is used for things such as playback of movies and MP3's, gaming (alot), large file downloads, ripping and burning CD's, things such as compressing and uncompressing of RAR files, and maybe some DVD compression later down the road. I know that the stripping size is different based on the types of activites and sizes of files used, but of all these things on one PC what would be the best option? My SATA controller allows stripping sizes between 16K and 512K and I currently have it set to 32K. Thanks a bunch all.
