Stripe size
iRoNeTiK
Vodka Martinis are for the Weak
What's a good stripe size if you are going to be using the array for your OS (Windows XP Pro)? Anything else I should take into consideration? I'm doing this with two WD SATA 7200RPM HDD's.
Thank You. Merry Xmas!
