Striker Extreme Powering On
BroDoug
Striker Extreme MB
Intel Core2 6700
A-Data 2GB DDR2 800
Western Digital 300Gb SATA
2 Samsung DVD S182M
Ultra X3 1000Watt Power Supply
Radeon HIS X1900 Video Card
LIAN PCA16 Case
I have not tried to overclock or tried to change anything from default settings...
My problem is that I cannot power up from the case button...
I have tried a different switch and does not power either...
I have checked and rechecked wire hook-ups and all seem to be hooked correctly...
The board will power up with the on board power switch and runs beautiful after that...
The reset button on case will work fine after I have system running...
Any help is appreciated... GRrrrrrrrrrrrrr
have you tried shortening the pins of the pwr switch on the mobo with eg a jumper or screwdriver ? if it boots then and works then you have a bad power switch in ya case, wire maybe loose or the switch itself is dead... if that trick doesn't work then there's been a shortcircuit on the mobo and it will never work from there then .. RMA then....
I have tried jumping the power button...
Also tried the button both ways by the read-out...
It must be the board and I hate that too...
