I have my P5N32-E SLI, I see that under the sticker it is it said striker extreme. Does this really mean it is a striker? And is it possible to use their BIOS on it?
Well Striker Bios has similar layout to P5N32-E so no need to try the flash...could be on the Striker Bios there might be slightly higher voltages allowed, but I've seen many Extreme Systems forum users already push this mobo way past 450FSB easily with adequate cooling...
Indeed PCB layout is the same but not all components are there some peeps talk about the LED and the flashy heatpipe being the only difference between the Striker board and the P5N32-E , I think there's more to it than just those gadgets...., real capacitors , some extra ones, better powercircuitry,...maybe not enough to persuade the average overclocker but the diehards and gimmick lovaas will go for the full monty...
If I get my hands on a P5N32-E plus I can compare the boards naked...one guy at legionhardware did a check but I find his comments really amusing as he didn't seem to find the lack of real capacitors ( reason why ASUS released the plus version) to be a good reason. Also his review is pretty late as he better compared the normal to the plus version which are in the same price range... and give us a reason why ASUS brought out this version and retired the other one....so quickly
