Citizen _insane
- May 2, 2006
I know this isn't the prefect venue for this type of question, but I'm not active on any other better suited forums.
I've been having an issue with streaming video that's driving me crazy. It has followed me (on the same build) from Windows 7 to Windows 10, although in 10 it's gotten worse.
When I press play, the video will buffer, but it won't start playing. If I scrub through the timeline, I can see the individual frames (so data is reaching my computer, it really is buffering), but it still won't play.
This behavior is consistent across multiple websites (youtube, vimeo, flickr, dailymotion) and with multiple playback software HTML5 & Flash behave the same. Proof since I wouldn't believe me if I said this either:
This problem is also occurs on all browsers, although the behavior varies a bit. On Firefox and Chrome, the video doesn't play. I can scrub through the timeline and see the frames, but nothing will make the video play. On IE, the video plays at about 3fps without sound, but will not play normally.
To solve the issue I have to reboot then everything works fine. If I leave the computer for some indeterminate about of time, it will be broken again. My computer is set to never go to sleep and to never hibernate. The only power save option turned on is turning off the monitors after 20 min. See sig for specs (it's the top one, main rig).
