el_lance_o
- Jul 9, 2004
alright, as the title says, my friend and I got a really really strange bug in his system. This is how it works: the thing runs fine and stable and all, but soon enough while in windows for maybe a couple minutes to an hour, a program will basically stop responding and you can't exit out of it, it'll just like stay there open not doing anything. Nothing will install even if you try, it either freezes at the last bar, or doesn't even go at all. Oh and if you hit the ol ctrl alt del the only thing that pops up is the little system use box in the taskbar thingy, and no window. This system is running 2,5 gigs memory, and an athlon xp 3200, so this is really really really strange and stupid.
