Strange XP behavior after Diskeepr and Perfect Disk install
mm00659
Hello. The system in my signature is only a couple of weeks old. All was going great until the last couple of days. I installed Diskeeper and Perfect Disk trial versions. I did some defragmenting with both softwares. Now, when I boot, certain things are non responsive for about 2 mins after the reboot. These things include internet explorer. I start it but I get a blank screen untill it comes out of this limbo state. Outlook Express, I forget if it starts and doesn't sync for 2 mins or if I double clisk the icon and it doesn't start until about 2 mins later. I did get some automatic updates from the windows update website installed. So I backed them out via add/remove programs but I still have the problem. Any ideas? Thanks. :confused:
Update. I just deinstalled both Diskeeper and Perfect Disk and the problem is gone. Not sure which one caused it because I removed both at the same time. But, when I am ready to buy one or the other, I will install one at a time and see which one causes this problem.
