just built my pc (should be listed below in sig) a couple of weeks ago.... well just noticed tonight that neither one of my 2 dvd-rw drives (brand-new) will allow me to "copy files to disk", as in my pictures on my pc, i want to adjust them in photoshop, then burn them to cd so i can go print them out.
the odd thing is, there isn't a "right-click" ->send to cd/dvd option for either drive....
when i right click on either one (i've tried both) and go to properties, there isn't even a record option (to enable recording ect) for either one of the drives...
another weird thing is, on my wifes computer she has an older cd/rw and one of the same dvd/rws as me.... she can "send to E: cd/rw" and it will burn fine, but when she tries to "send to D:dvd/rw" (the new drive) it won't burn all the way, but it does have the record tab under properties.
(this leads me to believe it might be a software problem but i don't know where to start)
also in the device manager both dvd/rw's are listed as scsi.....they are hooked up via ide cables, what's up with that?
need help/advice asap
Thanks
Thanks
