MasterShredder
- Jan 3, 2002
I've been noticing a really odd problem recently and just figured out what the issue is, but need help finding a solution. I have a DFI Lanparty NF3 250gb motherboard with an Athlon 64 3000+ setup and everything's been running wonderfully. Yesterday, I went to plug in an external USB drive and my computer just shut off. I went to check the power strip, but everything else seems to be fine. Today, I went to plug in my iPod and it did it again. I rebooted and wanted to run a chkdsk to make sure I didnt have any bad sectors (which i do
) and noticed the computer gives me a POST beep, but just hangs right after.
I hit reset on my case and get the same result. If I unplug the ipod and reset, it comes up fine.
Recently, I put in a promise TX2 card and added 2, 200 gig HDD's in a RAID 1 because my server box took a dive. I have a ThermalTake 480 watt powersupply, so i'm guessing I should have enough juice. I have the following components in my computer:
primary sata HDD,
2, 200 gig ata100 drives
promise card
dvd burner
hauppauge pvr 150 capture card
radeon 9800
Does anyone have any ideas before I start ripping open my computer and messing around? This is quite annoying
primary sata HDD,
promise card
dvd burner
radeon 9800
