PolygonGTC
- Jan 6, 2006
I finally got my new system up and running after replacing a DOA video card. After getting all the drivers and Windows updates done I installed Speccy and fired it up. All the temps seem fine until I look at the mother board which is reading 81° C and occasionally drops down to 60° C for a slit second. So, I loaded up Speed Fan and it was reading that the CPU was 81° C while Speccy was reporting 32° on the processor.
Using an IR thermometer I started checking everything and nothing was over 31° C on the surface. I figure if anything were really 81° C they'd show much higher than 31° C on the surface of the heat sink.
I'm just wondering if I should be concerned. Perhaps there's something better I can use to measure the temps? Also, I assume that the sensor for the mother board would be in the chipset? If not, where?
