Strange (static?) problem.
Cr3at1ve
Hey folks,
One day, while browsing the web, my computer screen went black, and the computer refused to boot when I tried to reboot. So, after some troubleshooting, I figured the motherboard was bad.
I ordered a new one from Newegg, and today, it came in. So, I built the computer on top of the case, which I layed sideways, and booted. No luck. After talking to Intel Support, and Asus support, I was still dumbfounded as to what it could be. So, I fiddled around with it, and suddenly, it began working with the new motherboard. Different combinations showed that it could be a bad stick of ram, and then on rebuild, I found it was my nic cards, wtf?!? Over and over again, new problems arose when old ones suddenly fixed themselves.
On some occasions, the computer wouldn't power at all. Sometimes, a spark would fly, but the system would be 100% a-ok. Sometimes, only 1 stick of my Samsung DDR would work, on other occasions, both work fine.
Im at a loss. I have no idea what to do. Perhaps its an enviormental problem, perhaps static is causing this? Any input would help, im very confused.
Cr3at1ve said:
Hey folks,
2 things you don't mention check that could point to your problem presented in order of most likely:
1) Power supply - could be overloaded and when you take something out it supplies enough juice. Could just be flakey. Try yours in another computer.
2) Extra standoff in the case - pull the MB and check for an extra one that could be shorting out the board to the case. could cause all kinds of wierdness.
Could be bad board too. Just cuz its new doesn't mean it works.
After taking a few days off to clear my head, ive gone back to testing.
I've tried another power supply in my computer, and no go. I tried my powersupply in another computer, and its working fine.
At this point, im running it bare. CPU, Vid Card, and PSU and Mobo. Nothing. No beeping, nada.
Being the poor college student I am, I can't afford to purchase parts just as a test. My brothers PC is an AMD, so there is only so much I can swap. We've swapped RAM, mine works in his, but not his in mine.
Ive tried running the computer out of case, nothing.
Any other ideas?
Can you at least afford to go buy a new mobo for testing purposes and then take it back? I know it kinda sucks but I've done it a few times to solve some problems.
You'll first have to strip it down further:
- place the mainboard on a piece of cardboard
- install only the CPU and HSF
- reset the CMOS
- install an external PC speaker if there's no onboard one
- connect the PSU
- turn the system on (short the PWR_SW pins of the I/O-header for a second)
- you should hear beeps now. Look them up; they should be for the RAM or videocard.
- add the missing component and turn the system on again
- the system should now complain about the other missing component; add it and turn it on again
- you should now be able to access the BIOS
Last year I battled with symptoms very similar to yours. Frustrating as hell, isn't it?
I bought a new motherboard and got the system to work.Then days or weeks later stuff started happening again. I took the whole computer into the computer store where I bought the motherboard and had them mess with it. Eventually they came to the conclusion that the CPU was bad, and I think one of my RAM slots was bad as well.
I had tried all sorts of combinations of RAM and had tried a handful of other processors. The most frustrating part was that the errors were SO eratic. With any given setup, the comp would either do absolutely nothing or if I was lucky it would give beep error codes. Every once in a blue moon it would actually post and boot.
My advice to you is to try a new CPU, in both motherboards. I ended up ruining two processors of mine because I reversed the clip on my heatsink (put pressure slightly off center from processor die). One CPU has visible chips in the die and the other looks fine, however both are bad ( although I've seen them boot while in this condition, just very rarely).
Try out your brothers CPU, and see what's doing.
I feel your pain buddy. I had to go through all this mess me too...
The only advice i can have is: Dont try to troubleshoot when you are damn frustrated..... your brain just doesnt work well during these times ahah
The best thing to do is pretty lame for your ego but..... leave this stuff to people that are getting paid for. I know most Of us here on the forum could solve the problem, if we spend hours and hours of testing and work......
Its better if you bring your damn computer to a computer store.... and let them find out whats not working.
