Strange power problems
Shogo
WEll i dont know if its related to my PSU, but the old p2 350mhz i have here seems to be possesed.
When i close the computer, i shut down the power , im 100% sure the computer is off power, and sometimes, it powers on by itself, no reason, the computer screen wich is plugged to the same powerbar still stay off.
It randomly shut down or power up with no reason. Maybe my psu is dead, its a generic 300w psu
what do you think so....
I have seen this and really can’t supply a viable explanation. I will tell you I cured one with a bios reset with the AC line disconnected. After that I went in and set the bios to the settings I wanted and the problem stopped. I also replaced the battery while I was in there.
It’s not much but I have seen this work.
Luck
