Strange P5K-E/WiFi-AP shutdown
egastal
Ok, this problem is really puzzling me. I've tested everything (except another CPU) and the problem persists. Could it be a faulty CPU? (The problem seems to occur when the CPU enters protected mode.)
Rig:
Asus P5K-E/WiFi-AP bios 1012
Intel Core 2 Duo E8400
Nvidia GeForce 8800GTS 512
2x1GB Crucial Ballistix DDR2-1066
2x1GB Kingston DDR2-1066 2x1GB
(Also tested with 2x1GB OCZ DDR2-800 Reaper HPC)
PSU Corsair VX550
Problem description:
PC POSTs fine. Runs OK in BIOS and MEMTEST. When booting into Windows, simply shuts down at the first loading screen of Vista. When booting Ubuntu Live-CD (with hard drives disconnected), shuts down after "Loading Linux Kernel".
Observations:
1) Problem started one week after the system was assembled.
2) Tested another PSU, same problem. Tested with less power demanding VGA (8600GT and 7600GS), same problem. RAM sticks were all tested in another MB, ran perfectly. Tested with only one stick of RAM on all 4 slots, same problem.
3) When left at the BIOS screen or boot selection screen (F8) to "warm up", PC would boot windows fine and ran stress tests OK, but ran HOT: 55°C MB temp, up to 50°C CPU temp under PC Probe II. Ambient temp around 30°C.
4) Some rare times, after using the "warm up" trick to successfully boot into Windows, the PC would shut down. (Seemed to coincide with when the case was opened to increase airflow).
5) After changing to a new case, with exaust fans and a new CPU Cooler, PC won't boot even when left at the boot selection screen to "warm up". A BIOS temp check shows that temps are LOW: 38°C MB temp, 34°C CPU temp. Ambient temp around 24°C.
6) When booting from a Knoppix Linux CD with Hard Drives disconnected from MB the system also shuts down. Tested with SATA mode as AHCI and IDE Enhanced.
7) Chassis FAN Speeds are randomly detected/not detected. But this seems to be a known problem.
8) Problem occurs with BIOS settings at default and many other settings tested.
9) Already tried reseating everything (including CPU). MOBO seems fine on visual inspection.
Any ideas?
Thanks
Had the same mobo to do similiar things, ended up being flakey bios wanted to control all memory timings and voltages. Was running ddr2 1066 @ 5-5-5-15 2.2v and rebooted and shut down. Then got some patriot ddr2 800 @ 4-4-4-12 2.0v did the same thing, Once I set memory to default and voltage to default It booted fine and no more problems. Got to be a flakey bios on mine. I sold the motherboard about 4 months ago for that reason. ALLEN
