wabbitseason
- Jun 16, 2010
Edit: Solved the problem, see post #4 for an explanation.
Hello folks,
Weird problem overclocking a 2500k rig (MSI Z68MA-ED55 mobo), with the following settings:
PLL: Auto
DRAM frequency, voltages, and timings: appropriate
Spread spectrum: Enabled
Vdroop Control: Auto
CPU I/O: Auto
System agent voltage: Auto
DDR_VREF_xxx: All set to"Auto"
PCH: Auto
I can boot into windows and run LinX flawlessly at the following core voltages/multis:
1.25/38
1.3/40
1.375/44
Temps are good. The problem is that when I restart, the system always fails to POST and the mobo reverts back to the last "stable" configuration. For example, if it just failed to post at 3.8--and I'd tried 4.4 previously--after a restart it'll actually revert to the 4.4 settings, not default!
I would think if these were unstable they'd be failing to boot into windows, let alone handling LinX for hours at a time. But somehow the restarting process is revealing some instability. Anyone have any idea what the heck is going on here? Thanks.
Hello folks,
PLL: Auto
CPU I/O: Auto
PCH: Auto
1.25/38
1.3/40
1.375/44
