Strange Noise When Turning the Computer on
Copycats
I Just put together my new Sandy Bridge build with:
Intel i7-2600K
ASUS P8P67 Deluxe mobo
4GB Corsair DDR3-1600
Intel X-25 SSD 128GB
WD Raptor 80G
nVidia GTX570 Superclocked
Antec TruePower New 750W
Coolermaster 690II Case
When I push the power button to turn on the computer, every time, there is some strange noise from the speakers which lasts about 3 secs then goes away. After that, everything is normal and the system runs fast and quiet. Sound is normal in windows as well. Later on I found out that turning on and off the power switch on the power supply generates the same kinda noise too. First I thought it might be the PSU to blame so I switched back to my old Antec True Power 430 but the noise remains.
I also tried different grounding methods to no avail.
Any idea what's causing this? Sounds like the PSU interfering with the motherboard?
sounds like the post speaker is having issues. If you have connected the case speaker to the mobo(in the bottom right part of the board) check to make sure the "speaker" connector is properly pushed on and not partially on.
The noise came from the external speakers not from the post speakers (post speaker is not even hooked up) ... I use the onboard audio and output through analog cables to my receiver.
