Strange mouse problem
Vlad335
Hello,
Just upgraded my box with a GigaByte GA-K8NS-939 and a A64 3500+. However, my mouse light on my MS optical mouse stays lit at all times. Even with the computer turned off. Also, none of the USB's work for my mouse so I have it plugged into the PS2 slot using the adaptor.
I did searches and saw that people recommended to disable "power up with mouse" options in the bios but this is already disabled.
Anything else I can try?
my MSI board does the same thing. dont worry about it its just not cutting the power to the PS2 ports when the comp is off. as for the mouse not working with the USB ports, make sure your USB ports are enabled in your BIOS.
