Strange Memory issue with this chaintech..
Monkey34
Ive got a Chaintech 7VIF4 SPECS socket A, Athlon 2400xp.
Heres the weird thing...had a stick of Kingston Valueram (ddr 2100) 256mb that posted at 192mb. Fine, I figure the stick had 64mb croak from static, so I buy a stick of Crucial thats listed for this motherboard (in case of compatibility issues also...you never know). It just came in, and its the same issue. I figure just RMA the mobo.........but has this ever happened to anyone before?
My guess would be you have the onboard video set to 64MB, which it takes from your total system memory. The option should be in the BIOS somewheres.
Yea, it does use up to 64mb for on-board video, but to show as 192? My last mobo with on-board video didnt do this. The memory shows as 192 in bios, and in windows. :confused:
umm why the bump, it has been explained. 256 - 64 for video memory = 192
You can go into the BIOS and lower how much RAM the onboard video uses and you should get some of that back, just to verify this is what is happening.
As to why it reports differently than your last MB, it is just how chaintech decided to do it. Just because your last MB with onboard video counted the video memory in the BIOS, windows should have reported the total as the total minus what the video used. (unless your last MB had it's own video memory and it was not shared memory)
==>Lazn
It was shared memory as well, and bios + windows showed the total ( not subtracting anything). I didnt think Durron was lying, I just wanted a second opinion ;)
If it was shared memory, then windows should not have showed the total.. something really strange there.
==>Lazn
