jubalskeiki
- Jan 27, 2005
I am not really sure where this goes, so I'll just guess at a forum and if it needs moving it can (sorry about that, not trying to create extra work for the mods).
I've been having issues with my computer for awhile now. It will just randomly lock-up on me. Sometimes the computer doesn't lock-up but the display will just kaput. I am not sure if these are related issues or not. I just replaced my video card a couple of months ago. I have re-installed all of my display software. I had read that it might have been weird codec issues so I have done my best to clean up my codecs.
I have thought about just reinstalling, but have been hesitant to do so because I am trying to preserve this install. I had a hard drive die and my profile was set to private so all of my files on that drive (which I had accidently mapped the root as my documents folder VS a folder on the drive) appear to be gone, but the file needed to decrypt them is on this drive and if I can ever get the files recovered I am afraid for them to do it they'd need the file. Unless I am completely off-base in my understanding of this. The XP encryption works by saving an encryption key in a system file which can be exported.
Is there something else I can try besides wiping everything and starting over? I guess my biggest fear is I'll do this and then it won't make a difference and I'll have wiped out any chance of recovering irreplaceable pictures (which I thought I had a backup of, but apparently not).
