Okay, this problem has gone from annoying to really bad....
A few days ago the lights on my Logitech keyboard (caps lock, num lock, and scroll lock) started blinking really fast when I turned on my computer, which I thought was rather odd. Then I discovered that my keyboard wouldn't function when it was doing its blinking thing. I figured that maybe my keyboard had died but when I plugged it into my little bro's box it worked fine and his keyboard worked fine on my computer...which was strange to say the least. When I swapped them back, however, my keyboard lights started to blink again and the keyboard still didn't function. I also tried plugging a brand new Logitech keyboard into my computer and it did the same thing as my older Logitech keyboard.
After a year of use, you'd think that your computer couldn't just suddenly decide that it doesn't like Logitech keyboards... So, I decided to try clearing CMOS today (with my little brother's keyboard plugged in) and that's when things got really bad. My computer will no longer POST (or even give a startup beep), it just sits there (black screen). I'm thinking that the mobo could be damaged/defective/dead. It continued to sit there and do a whole lot of nothing even when I cleared CMOS a second time...and my Logitech keyboards still do nothing but blink. Any ideas/suggestions?
BTW, the computer in question is the one that's in my sig. (the mobo is only about 5 months old and NewEgg will still allow me to RMA it, if that's what needs to be done...)
