KurtHansen1988
- Sep 3, 2015
So I picked up a pretty much brand new Asus Eee Box B206 at a yard sale for $7 which was an awesome deal. Booted it up and no operating system found, whatever. I have an Easy2Boot USB drive with tons of operating systems on it and decided to boot into Linux Mint 17.3 and checked the S.M.A.R.T status of the drive. Everything was good. Total power on time was 157 hours. Tried to install to HDD and installation hangs. Tried Windows 7/8 and same issue but I got an error code "0x80042405" couldn't find any info about this. Rebooted and I got this screen on post.
I decided to hook up the drive to my main computer and did a low level format and partitioned the drive as primary NTFS and Windows 8 was able to see the drive & read/write just fine. Hooked the drive back up and also updated to the latest bios. Tried to boot Linux Mint again. This time.
I rebooted and decided to give Windows 8 installation a try again, but this time upon booting instead of loading the Easy2Boot UEFI I got a blank screen after post that simply says "Virus!" I rebooted again and this time it loaded E2B no problem. Rebooted 10+ more times and I haven't scene the "Virus!" screen since. I haven't found anything on google about my issue other than it could possibly be a boot sector virus.
Here is the info using Seatools.
Model# ST9160310AS
I notice that security mode says "Supported, frozen" not sure what that means though. Any one else run into similar problems or know a fix (other than using a different hard drive?
Model# ST9160310AS
