Basically my install of WinXP is failing to find the IDE drivers. Neither SATA nor raid is involved. Mobo is Biostar M7NCG, a nForce2 based board. HDD is a WD 80GB. I have tried designating it as a single drive and as cable select. Both methods show the HDD as IDE 0 on primary channel.
If I boot from CD and hit F6 to specify additional drivers it shows that no mass storage drivers were detected. The HDD is new and was just tested on a secondary channel of another system.
Memtest came back with no errors.
I am stumped. I have done the exact same installation in the past with a Seagate drive and had no problem.
Possible causes that I can think of:
-some strange issue with the drive and the Nforce2 board
-Sunspots
-IDE controller part of the chipset was eaten by gremlins
Anyone have ideas on what is causing this?
-Sunspots
