Gatecrasher3000
- Mar 18, 2013
Hi everyone, so I have been getting some strange behavior with my home wifi setup, and I was wondering if any of you had seen it before.
My problem:
When on mobile or my laptop, I am able to connect to my home wifi without problem. Browsing web pages or the reddit app/youtube usually loads links/videos quickly. However, some things do not work. Gifs, when clicked on in the reddit app, do not load. Also, when opening the tumbler app, tumbler never loads new content. It seems I have strong speeds in some applications, but not others.
My setup:
2 (one for each floor of my apartment) Asus RT-N66U wifi routers, with 250 mbit line. Router 1 is connected to the modem, and router 2 is connected to router 1. Each router has the same configurations, except with different IPs (xx.xx.1.x, xx.xx.2.x). I receive no problems when connect via cat 5.
My troubleshooting attempts:
Like I said I have a 250 mega bit line so I know speed is not a problem, plus each my phone and my laptop report 250mbit when testing the speed on speedtest/google speed test (although much slower on google speed test..). Using my laptop, I have run a packet loss test, but it reports 0% loss. I have been getting this problem since using only 1 router so I don’t believe the two routers are interfering with each other. I do live in an apartment, would channel interference create issues like this? Also, I never have connection issues on my systems that’s are connected via cat 5.
When using the wifi analyzer app, I receive strong signal throughout my apartment, I don’t believe it’s a dead zone issue.
At this point Im guessing it’s some little setting in my router’s settings that I don’t know about.
ANY suggestions would be appreciated!
Thank you!
My problem:
My setup:
Thank you!
