This is a somewhat long story, so I apologize in advance. Also if this is the wrong place would a mod please direct me to the right place to ask it?
The Situation:
(see sig for specs)
I just bought a Seagate (7200.10) SATA HD from the egg, this being my first sata drive i was pretty stoked. The drive arrived, I plugged it into my system (after removing the jumper that seagate indicated was for factory use only) and tried to boot everything back up.
Only to find that while my system would detect the sata drive it failed to find any of my ide devices (2 optical drives, 2 ide hd) but the sata drive showed up find. This...perturbed me to say the least so the fun began.
Things I've done so far:
1. Reseated all cards and connections, no change
2. disconnected everything except my gfx card and my primary boot drive, still no ide detection.
3. swapped my hd from ide channel 1 to ide channel 2, no hd detection
4. put my optical drives on ide channel 1 (no hd connected), they show up
5. put optical back on ide channel 2 (no hd connected), they show up
6. optical connected to ide channel 2, sata drive connected to sata1, the hd and the optical drives show up
7. reset cmos using cmos jumper on Mobo, no change.
8. Swapped out my corsair 620w ps for an older thermaltake 430w, no change
What i finally ended up doing was just formatting the sata drive with windows xp, throwing my other drives in an external enclosure and pulling the data off i need from there. (they show up fine through the enclosure and usb 2.0 connection).
So from what i gathered something is wrong with my ide channel 1, or I should have left the factory installed jumper on the sata drive? I'm trying to figure out what the hell exactly went wrong here and if i should just bite the bullet and get a new motherboard (socket 939). Stumped I am, any thoughts or ideas would be appreicated.
If you need more info just lemme know.
Yarrr
The Situation:
(see sig for specs)
Yarrr
