I really hope someone can help me out with this... I've spent a lot of time thinking of different causes to this problem, and got nothing... so hopefully someone else might be able to help me. Here's my problem...
A while back I had a problem where when I minimized a window, the hard drive would be accessed for a quick second, then stop, then accessed again, then stop, and so on... Pretty close to a second interval. It'd do it for about 10 seconds or so after I minimzed the window. But when it does that, the computer would freeze just a very tiny bit. So if I was watching a movie, it'd get a little choppy. Even if I just move the mouse, it'd actually freeze for a split second. The actual freezing is very minor, but also *very* annoying. And it wasn't just with minimizing a window. I remember it doing it in games too, but only when just launching the game, for like the first minute into it.
Well, anyways, I did a format and reinstall of windows at the time, and everything worked great! Well... it's been months later... and suddenly it just showed up again out of no where! I would love to fix this without having to reformat. Especially since this a reoccuring problem, I don't want to have to reformat everytime it comes around. And sadly, I *would* have to, cause it's very noticable to me.
My system specs are:
Windows XP Home SP1
Pentium 4 2.26Ghz
512MB RAM
Dual 80GB Hard drives
NVidia GeForce4 MX420
Besides the problems I mentioned, I noticed the system seems to bog down much easier when the hard drive is being accessed. Like when I play an mp3, normally it'd NEVER chop up, or stutter in play. But now, if I go to run a program, it takes longer to run it, and the mp3 will stutter and stop for a second or two. Also, windows seems to take quite a bit longer to load now...
I have done scans with AVG and the latest virus defs, BOTH SpyBot and Ad-Aware, both using updated reference files. I have done a full surface ScanDisk, and done multiple defragmentation runs on the drive. I even tried playing around with the paging file and it's settings, thinking maybe the extra HD access is something with the paging file. And I see nothing out of the ordindary on my processes list... I just don't know what else to try.
It's funny too, cause I didn't do anything to cause it. Like new software, or new hardware... it just happened.
Thanks for reading this, and please feel free to express your thoughts on this! I'll take any advice at this point! Thanks very much
Windows XP Home SP1
Pentium 4 2.26Ghz
512MB RAM
